  3. How do people generate layer stack-up files for PCB manufacturer...
  • Views 20042
How do people generate layer stack-up files for PCB manufacturer?
doginwater
doginwater over 11 years ago
I am trying to generate stack-up information for PCB manufacturer, in a PDF format? Does PCB Designer have a function to do this?
Thanks for your help.
  • steve
    steve over 11 years ago
    You could use Manufacture - Cross Section Chart which adds the stackup information into a graphic. Put it on the canvas then display what you want and then use File - Plot change the Setup to choose a PDF printer (like CutePDF) and create the drawing.
  • doginwater
    Thank you.
    Is there a way to add solder mask information to the cross section chart?
  • steve
    Yes - Add it to the cross section (Dielectric layer) above and below TOP and BOTTOM. Edit the materials.dat file located in <your_install_dir>\share\pcb\text and add a new dielectric material called SOLDERMASK, (best to copy an existing one). Then change the dielectric material in the cross section.
  • ichliebedich
    ichliebedich over 5 years ago in reply to steve
    how can I change the displayed color of cross section? I tried to find Xsection attribute in color dialog, there was no any option to select color that I want
  • RFinley
    RFinley over 5 years ago in reply to ichliebedich
    When you export it as ODB/IPC/Gerber, these don't have colors, only layers.
    For layout display, it's under Manufacturing/NCDrillLegend using the color chooser.
