  3. SKILL function to 'get' the DRC Marker Size set by user...
  • Views 3075
SKILL function to 'get' the DRC Marker Size set by user in 'Design Parameters' window
BinduSripad
BinduSripad over 11 years ago
I am trying to capture the user-defined  'DRC Marker Size' in 'Design Parameter Editor' window. The Allegro SKILL manual indicates using axlDBDisplayControl to access the "drcMarkerSize" control.
But axlDBDisplayControl ('drcMarkerSize) always returns nil.
I tried recording a macro to set the DRC marker size and here is the script:
prmed
setwindow form.prmedit
FORM prmedit drc_marker_size 50.00
FORM prmedit apply
FORM prmedit done
Seems like this is to 'set' the marker size. How do I 'get' this marker size and save it in a variable in SKILL?
Thanks for the help!
Bindu
  • jwhend
    jwhend over 11 years ago
    Leave off the "r" use 'drcMakerSize. axlDBDisplayControl('drcMakerSize)
  • BinduSripad
    Thanks a lot! This works. I would have never guessed the spelling error :) Hope this is being fixed.
  • B Bruekers
    B Bruekers over 11 years ago
    Look at the "share\pcb\examples\skill\DOC\FUNCS\axlDBDisplayControl.txt"
    I always check this directory (and others in the \skill\DOC\) when a function does not work as expected.
