  3. Accessing Symbol User Defined Properties in a Board Fil...
  • Subscribers 160
  • Views 13390
Accessing Symbol User Defined Properties in a Board File
Grungy Remnant
Grungy Remnant over 10 years ago
Hi.  I'm trying to access user defined properties at the drawing level on a symbol after it's been placed in a board file.  Is this possible?  None of the properties show up on the symbols in the board file.  I'm wondering if it's the way they are defined that's causing problems.
The properties were added to the symbol .dra like this:
axlDBCreatePropDictEntry("Custom_Prop" , "string", "designs")
axlDBAddProp( axlDBGetDesign() list( "Custom_Prop" "Some Text"))
I cannot find a way to access these properties from within the board file after they have been placed.  Any suggestions?
Thanks for any help
Chris.
  • oldmouldy
    oldmouldy over 10 years ago
    axlDBGetPropDictEntry? Check the algroskill.pdf in the doc\algroskill directory of the installation.
