  3. Weird problem , running same code twice make allegro freeze...
  • Views 1156
Weird problem , running same code twice make allegro freeze/crush
stillfish
stillfish over 10 years ago
I have digged for a while but still have no idea why.
Following code can reproduce the problem,
the net name "M_A_DQ<0>" could be changed to any valid net.
r_net = axlDBFindByName('net "M_A_DQ<0>")
l_children = foreach(mapcan x r_net->branches x->children)
l_path = setof(x l_children equal(x->objType "path"))
l_segments = foreach(mapcan x l_path x->segments)    ; works perfect when first run
l_segments = foreach(mapcan x l_path x->segments)    ; make my allegro crush......
  • stillfish
    Well, i guess i know why.
    foreach + map function use destructive modification function nconc to concatenate list.
    therefore all other path's segments are append to first path->segments in database...
