  3. Place Manual Toolbar Button Does Not Work
  • Subscribers 166
  • Views 17485
Allan M
Allan M over 10 years ago
Hello Folks,
I am using OrCAD PCB Designer Professional Version 16.6-2015 S061 (v16-6-112EW) [11/9/2015] Windows 32.  My OS is Microsoft Windows 7 Professional   6.1.7601 Service Pack 1 Build 7601 64 bit.
When I try to click on the "Place Manual" button in the Place toolbar, nothing happens.  The Placement dialog simply does not appear. I can select Place Components Manually from the Main Menu but the toolbar button does not work at all.
Is this a bug?  Is there a setting I can use to fix this?  I am totally stumped.
Allan
  • oldmouldy
    oldmouldy over 10 years ago
    This has been a (reported) bug since the OrCAD 2015 update, I don't believe that there is a workaround to "fix" the toolbar button action.
  • Allan M
    Thanks oldmouldy. I guess I'm not crazy after all!
  • avocadacurry
    avocadacurry over 6 years ago
    What did you do to solve?
