  3. Finding the width of a thermal cline
  • Subscribers 163
  • Views 15236
Geoff
Geoff over 10 years ago
I am trying to get the width of thermal clines on a pin, but no success.
Here is what I am doing.
connections=axlDBGetConnect(pin t)
foreach( con connections
   printf("%s %s %L %n\n" con->layer con->objType con->thermal con->width)
   printf("    segments: %L\n" con->segments)
  );foreach
The width attribute isn't an available attribute, but shouldn't it be?
How do I find the cline width?
  • jwhend
    jwhend over 10 years ago
    The width is in segments, you will need till do a foreach on con->segments to get the width of each segment.
    Try this:
    axlSetFindFilter(?enabled list( "noall" "pins")
                    ?onButtons list( "noall" "pins"))
    axlSingleSelectPoint()
    pin=car(axlGetSelSet())
    connections=car(axlDBGetConnect(pin t))
    foreach( con connections->segments
       printf("    segments: %L\n" con->width)
      );foreach
    --Jerry
  • Geoff
    I couldn't get your code to work, so I came up with this, that works.
     pin= car(axlGetSelSet())
     axlClearSelSet()
      printf("%s\n" con->layer)
      foreach(seg con->segments
       printf("    Width: %L\n" seg->width)
      );foreach
     );foreach
    Thanks for the help, Jerry
