  3. Add via to a design using SKILL
  • Subscribers 163
  • Views 15981
BinduSripad
BinduSripad over 10 years ago
Hello everyone,
Does axlDBCreateVia() add the via to the design or it just creates the via? If so, what is the command to add the created (new) via to the design?
I have the following code to create new via using an existing padstack and connect it to net1:
new_via = axlDBCreateVia("pad_stack1", 3030:3045, "net1")
But these print commands display nil
printf("New Via Name: %L\n" new_yvia->name)
printf("New Location: %L\n" new_via->xy)
printf("New Start and End layers: %L\n" new_via->startEnd)
Bindu
  • Kirti Sikri
    Kirti Sikri over 10 years ago
    It does create a via. But return value of the function axlDBCreateVia is a list if successful or nil.
    So try via1=car(via) and then print the values.
    For example in final.brd that I have I created
     a = axlDBCreateVia("VIA", 1150:1950, "vd4")
    return value or a was (dbid:239002504 nil)
    a1=car(a)
    a1->name gave result as Via.
    Kirti
  • BinduSripad
    Thanks, it works.
