  3. PIN select issue
  • Replies 7
  • Views 18024
PIN select issue
catalineacsu
catalineacsu over 10 years ago
I am working on a skill that generates a report with vias in pad but I am having problems using the single select function. It selects pins that are not overlapping the via but instead are 20 mils away. When I am running running the code line by line it works fine. If anyone spots a mistake please let me know. Or a workaround better than axlSingleSelectBox, which works better but not perfect...
The logic behind it is:
1. turn on vias and pads on one side of the pcb
2. select all visible vias
3. parse the list and select the pins overlapping the center of the via
4. report the result
The code is below (please forgive minor mistakes in the code if any. I have a 99% working code implemented with axlSingleSelectBox function and the one below is recreated from memory):
    axlWindowFit()
    axlVisibleDesign(nil)
    axlVisibleLayer("PIN/TOP" t)
    axlVisibleLayer("VIA CLASS/TOP" t)
    axlUIWRedraw(nil)
    axlClearSelSet()
    axlSetFindFilter(?enabled '(noall VIAS) ?onButtons '(noall VIAS))
    topvias = axlGetSelSet(axlAddSelectAll())
    axlClearSelSet()
    axlSetFindFilter(?enabled '(noall PINS) ?onButtons '(noall PINS))
    foreach(via topvias
        axlAddSelectPoint() ; this is the line that is not working!!!
    vippinlist = axlGetSelSet()
    axlClearSelSet()
  • DE202408202727
    DE202408202727 over 10 years ago
    Try using axlAddSelectPoint(via ->xy)
  • catalineacsu
    Dave,
    sorry for the typo.
    that is exactly the syntax I used.
    It has the same faulty behavior with window select function, although the number of failures is significantly lower.
    regards,
    catalin
  • catalineacsu
    and the fragment from the routine I use now: axlSetFindFilter(?enabled '(noall VIAS) ?onButtons '(noall VIAS))
    bottomvias = axlGetSelSet(axlAddSelectAll())
    axlClearSelSet()
    fprintf(Log_File "\n\nBottom VIPs:\n")
    fprintf(Log_File "Location\n\n")
    foreach(via bottomvias
    Xvia = xCoord(via->xy)
    Yvia = yCoord(via->xy)
    LL = list((Xvia - halfwindow) (Yvia - halfwindow))
    UR = list((Xvia + halfwindow) (Yvia + halfwindow))
    BB = list(LL UR)
    ;axlClearSelSet()
    if(axlSingleSelectBox(BB) == t then
    fprintf(Log_File "%s @ \t (%.2n %.2n )\n" via->name xCoord(via->xy) yCoord(via->xy))
    axlClearSelSet()
  • B Bruekers
    B Bruekers over 10 years ago
    Try this piece of code:
    ;first get only pins which are not through-hole
    l_pins= tconc(nil nil)
    foreach(symb axlDBGetDesign()->symbols foreach(pin symb->pins unless(pin->isThrough l_pins= tconc(l_pins pin))))
    ;make a flat list, remove nil
    l_pins= remq(nil car(l_pins))
    axlSetFindFilter(?enabled '("NOALL" "VIAS") ?onButtons '("NOALL" "VIAS"))
    l_padvia = tconc(nil nil)
    foreach(pin l_pins
    if(car(pin->startEnd)=="ETCH/BOTTOM"
    then lay= "ETCH/BOTTOM", axlVisibleLayer( "VIA CLASS/TOP" nil), axlVisibleLayer( "VIA CLASS/BOTTOM" t)
    else lay= "ETCH/TOP", axlVisibleLayer( "VIA CLASS/TOP" t), axlVisibleLayer( "VIA CLASS/BOTTOM" nil)
    poly = car( axlPolyFromDB(pin ?layer lay))
    pinxy= pin->xy
    when(poly
    axlClearSelSet()
    ;make small selection around pin, only continue when a via found
    when(axlSingleSelectBox(poly->bBox)
    l_vias = axlGetSelSet()
    foreach(via l_vias
    ;check if via is within the pin poly, if so add to list
    when(axlGeoPointInShape(via->xy poly) l_padvia = tconc(l_padvia via))
    l_padvia= remq(nil car(l_padvia))
    axlClearSelSet()
    ;l_padvia contains a list of via DBID which are in pad.
    pprint(length(l_padvia))
    pprint(l_padvia)
  • catalineacsu
    Hello B Bruekers,
    I thought of doing it the other way round, as you suggested and I am sure that is a good option to solve at least a part of my problem. However, going that way has some disadvantages:
    1. for the large rectangular pins which are placed at 45 degree there is some room for error as well, as some vias can "hide" in the corner of the bounding box
    2. it moves my attention from the interesting problem I found. As I said, with window select, the failure rate dropped (from 50% to about 1%), which is somehow acceptable.
    3. the code moves away from the elegant and optimized solution I initially had in mind, select the vias and then select the pads that contain the center of the via, transforming 2 lines of code in 15 or more.
