  3. Help! Documents for beginner.
  • Subscribers 166
  • Views 18794
halinh12sinh
halinh12sinh over 10 years ago
Hello everyone,
I am a beginner with allegro skill.
I'm trying to read a piece of skill program as follows:
WIDTH_ScriptText = strcat(
"setwindow pcb ;"
"setwindow form.mini ;"
"FORM mini line_width " WIDTH_Number " ;"
"setwindow pcb ;"
WIDTH_Select = car(axlGetSelSet())
WIDTH_PadSelect = WIDTH_Select->pads
I having some issues:
+I can not find any information about the command" setwindow" in the document "Allegro User Guide: SKILL Reference"
and "SKILL Language User Guide"
+properties of the object in the allegro.(example:WIDTH_PadSelect = WIDTH_Select->pads)
Can you show the documents containing this information?Please!
Thanks and best regards,
Ken Le
  • catalineacsu
    catalineacsu over 10 years ago
    these are not skill commands but script commands.
    There might be a better way to do it, but I personally learned them by recording scripts and then debugging them. Usually their names are quite intuitive.
    File->Script->Record/Stop.
  • B Bruekers
    B Bruekers over 10 years ago
    You can also use "scriptmode +e"  (Allegro command prompt, not skill!) to find out certain script commando's. ( scriptmode -e to disable)
    Another hint, pressing ctrl-p in a form (like the artwork setup) will generate a file with all fields that are available on that form.
  • halinh12sinh
    Hi catalineacsu and Bruekers
    Thank you very much! Your answers are useful.
    By the way,Do you know any separate tool to write and debug Skill?
    I'm reading a "change line width" skill. Please review the "Hight light" code bellows:
    one question, how can we know the properties of each object? such as "WIDTH_Select->pads"
    ; command: skill load("setwidth.il")
    ; command: w *
    ; WARRANTY: NONE!
    ; Must be called inside the "add connect" command
    ; - If you want to set Line Width to 25 mils, type: "w 25"
    ; - when you pick smd pad (ex: smd18x80) If you want to change
    ; the Line Width to the Width of pad size, only type "w"
    ; The Line Width will be change to 18mils.
    ; - when you pick on a trace (ex: 35 mils) If you want to change
    ; the Line Width to the Width of current trace, only type "w"
    ; The Line Width will be change to 35mils.
    axlCmdRegister( "w" 'WIDTH_Start ?cmdType "sub_cmd")
    defun( WIDTH_Start ( @optional ( WIDTH_IsNumber "150" ) )
    if(WIDTH_IsNumber==nil then
    WIDTH_Auto()
    else
    WIDTH_Out(WIDTH_IsNumber)
    );end-if
    );end-defun( WIDTH_Start )
    defun( WIDTH_Out ( WIDTH_Number )
    version = axlVersion('version)
    if(version<16.0 then
    "setwindow pcb ;"
    "setwindow pcb ;"
    else
    "setwindow pcb ;"
    "FORM mini acon_line_width " WIDTH_Number " ;"
    "setwindow pcb ;"
    );end-if
    axlShell(WIDTH_ScriptText)
    printf("Change width to %s mils\n" WIDTH_Number)
    WIDTH_Number = nil
    WIDTH_ScriptText = nil
    );end-defun( WIDTH_Out )
    defun( WIDTH_Auto ()
    WIDTH_PadMirrored = WIDTH_Select->isMirrored
    when( WIDTH_Select->objType=="pin"
    when( WIDTH_Select->isThrough==nil
    foreach(WIDTH_PadElem WIDTH_PadSelect
    when(WIDTH_PadElem->type=="REGULAR"
    when( ((WIDTH_PadElem->layer=="ETCH/TOP")&&WIDTH_PadMirrored==nil)||
    ((WIDTH_PadElem->layer=="ETCH/BOTTOM")&&WIDTH_PadMirrored==t)
    WIDTH_bBox = WIDTH_PadElem->bBox
    WIDTH_DisX = caadr(WIDTH_bBox)-caar(WIDTH_bBox)
    WIDTH_DisY = cadadr(WIDTH_bBox)-cadar(WIDTH_bBox)
    ;WIDTH_Width = truncate(min(WIDTH_DisX WIDTH_DisY))
    WIDTH_Width = min(WIDTH_DisX WIDTH_DisY)
    WIDTH_Width = sprintf(nil "%L" WIDTH_Width-1)
    WIDTH_Out(WIDTH_Width)
    );end-when
    );end-when
    );end-foreach
    );end-when
    );end-when
    when( WIDTH_Select->objType=="line"
    WIDTH_Width = WIDTH_Select->width
    WIDTH_Width = sprintf(nil "%L" WIDTH_Width)
    );end-when
    );end-defun(WIDTH_Auto)
  • catalineacsu
    Hello  Linh Le,
    I am using notepad ++ for writing the SKILL style. You can define your own style. For debugging, I use the skill command line in Allegro and place useful variable inside the code to see what is going on in case of troubles.
    as for the properties there are a few ways to find them out.
    1. The "Allegro PCB Editor Database User Model" chapter in "Allegro User Guide: SKILL Reference" pdf document
    2. in skill command line by using my_id->? or my_id->??
    I usually use this code to interrogate different items (symbols in this example):
    axlSetFindFilter(?enabled `("NOALL" "SYMBOLS") ?onButtons `("SYMBOLS"))
    axlSingleSelectPoint()
    x = car(axlGetSelSet())
    and then type:
    x->xy
    x->?
    x->??
    etc.
  • halinh12sinh
    You're a genius.^^ Thanks for your help.
