  3. Set few cells in first row of a grid to * and gray out rest...
  • Views 15091
Set few cells in first row of a grid to * and gray out rest of the row
BinduSripad
BinduSripad over 10 years ago
Hi SKILL experts,
I have a grid in a form with last column having a pull-down (combo-box). I have to set the few cells in 1st row to "*" and gray out rest of the row.
The following code sets the 2nd and 3rd cells in 1st row to "*". I am not able to figure out how to gray the rest of the row.
_setCell = axlFormGridNewCell()
_setCell->row = 1
_setCell->col = 2
_setCell->value = "*"
axlFormSetField(myform "ListView1" _setCell)
_setCell->row = 1
_setCell->col = 3
Please help!
Bindu
  • B Bruekers
    B Bruekers over 10 years ago
    Hi
    First look at the example fgrid.il in <cdsroot>/share/pcb/examples/skill.
    Best practice is to use the axlFormGridSetBatch function, and make defun in which you update/fill the grid.
    If you type axlFormGridNewCell()->?? then you get the cell structure:
    Skill > axlFormGridNewCell()->??
    (row 0 col 0 value
    nil backColor nil textColor nil
    check nil noEdit nil invisible
    nil objType "gridCell" scriptLabel nil
    popup nil
    So by using _setCell->noEdit=t  and _setCell->backColor='button you can 'grey out' the cell and set a no-edit.
    Btw, you only need to call once _setCell = axlFormGridNewCell(), and then you can change the values and call axlFormGridBatch(_setCell) to update the cell.
    so;
    _setCell=axlFormGridNewCell()
    _setCell->row=1
    _setCell->cell=1
    _setCell->value= "row1col1"
    _setCell->cell=2
    _setCell->value= "Row1col2"
  • BinduSripad
    Hello B Bruekers,
    Thanks for the solution!
    _setCell->cell did not work. But, this did:
    _setCell->row = 1
    _setCell->col = 1
    _setCell->col = 2
    _setCell->col = 3
    _setCell->noEdit = t
    Bindu
