  3. Adding lines to a listbox from a text file
  • Views 16006
joma
joma over 10 years ago
Hi, I am trying to populate a listbox from a text file but I get an error:
E- *Error* axlFormSetField: argument #1 should be any user-defined (other) type (type template = "otg") - nil
I use the following to read my file:
        putd('pmGetListOfNotas nil)
        (defun pmGetListOfNotas ()
            axlUIWPrint(nil " Get List" "(" ")")
                notas_port = axlDMOpenFile("ALLEGRO_TEXT" "./nota_list.txt" "r")
                        while(
                        notas=gets(notas notas_port)
                        ;notas=lineread(notas_port)
                            l_notas=tconc(l_notas notas)
                            println(l_notas)
                        ); end while
                    l_notas=car(l_notas)
                            println(l_notas)
                            axlDMClose(notas_port)
                            l_notas
        ); defun pmGetListOfNotas
The  text file I use for testing is simply:
NOTE1 and -text
NOTE2 and +more text
NOTE3
and the println(l_notas) command returns the list:
("NOTE1 and - text\n" "NOTE2 and +more text\n" "NOTE3\n")
My code for adding the list to a listbox is:
         putd('pmAddnotasToForm nil)
         (defun pmAddnotasToForm (l_notas)
             axlUIWPrint(nil "liste de notas " "(" ")")
             if(zerop(notas) then
                 axlFormSetField(NoteForm "NotaList" "No Notas Found")
            axlUIWPrint(nil "No notas found" "(" ")")
             else
                 foreach(note l_notas
                    axlUIWPrint(nil " Foreach Notas" "(" ")")
                     axlFormSetField(NoteForm "NotaList" note)
                 ); foreach
             );if
;        );let
         ); defun pmAddnotasToForm
        axlUIWPrint(nil "** Gathering notas , please wait. **" )
        pmAddnotasToForm(pmGetListOfNotas())
        axlUIWPrint(nil " -Get list of notas Done - " )
I then have two problems to resolve. One is the error that come from the "axlFormSetField" in the foreach loop and the other is to remove the last two characters (\n) from each list element before inserting in the "axlFormSetField" line. The \n characters come from the gets command but if I use the lineread command instead I get my input line broken up if I have any special characters in it.
Any help appreciated.
Jim O'Mahony
  • DE202408202727
    DE202408202727 over 10 years ago
    Hi Jim,
    1/
    You need to pass the NoteForm variable from the calling function. Your function should start with:
    (defun pmAddnotasToForm (NoteForm, l_notas)
    2/
    You can use axlStringRemoveSpaces to strip the \n characters.
    An alternative is to use the substring command:
    substring(note, 1, strlen(note) - 1)
    Dave
  • joma
    Thanks Dave, that worked.
    Jim.
