  3. Custom report
  • Views 15423
Custom report
MANI BHARATHI
MANI BHARATHI over 10 years ago
can anybody tell me how to generate via report, with their corresponding connected component detail with pin number,
for example :- i am using 2 via for refdes R1 means, when i generate via custom report, the report must show VIA DRILL SIZE, VIA_X, VIA_Y, VIA_CONNECTED_REFDES, REFDES_PIN_NUMBER, NET_NAME
thank you,
  • DE202408202727
    DE202408202727 over 10 years ago
    via ->net ->branches gives you a list of branches connecting the net associated with each via
    branch ->children gives you the set of objects connected to each branch
    pins are are a subset of that list.
    fprintf can be used to print a formatted string using that information.
  • EvanShultz
    EvanShultz over 10 years ago
    Instead of going bottom-up, axlDBGetDesign()->nets will give a list of all nets in the design which you can traverse. There might be another way to get to vias, but it depends on where you're starting.
    See the section "The Allegro PCB Editor Database User Model" in algroskill.pdf for more information on database object and their relationships.
