  3. Errors using Artwork batch command after update?
  • Views 17442
thewill2live
thewill2live over 10 years ago
Hey guys,
A while back I made a skill script that calls the artwork.exe batch command to output artwork files for a board. The script would run something like the following line:
axlRunBatchDBProgram("artwork" "artwork -f ASSY -f LAYER01 -f FAB -f LAYER03 -f LAYER04 -f LAYER02 BoardName.brd")
This had run fine for many months and then our office just updated to Allegro 16.6-2015 S068 and now we're seeing errors from this command. After running it, the return value is 1 and we see the following message in the console:
E- (SPMHGE-268): artwork had errors, use Viewlog to review the log file.
The logfile window pops up asking you to pick out a logfile and there's no errors written in the logfile. Artwork files were all created perfectly fine, it's just a recurring false error that pops up. Has anyone else noticed this? Any idea how to work around it?
  • fxffxf
    fxffxf over 10 years ago
    Try updating it to tell axl run batch that artwork is a program that return warnings:
    axlRunBatchDBProgram("artwork" "artwork -f ASSY -f LAYER01 -f FAB -f LAYER03 -f LAYER04 -f LAYER02 BoardName.brd" ?warnProgram t)
  • thewill2live
    Gave that a shot. Same response. Returns 1 and artwork IS output correctly and the error message is still present.
  • DE202408202727
    DE202408202727 over 10 years ago
    Try this (or something like it):
    axlRunBatchDBProgram("artwork" strcat("artwork -f TOP " axlCurrentDesign(), ".brd"), ?noUnload t ?logfile "photoplot.log", ?warnProgram t)
  • thewill2live
    So I ran your suggestion eDave, and it worked, then I set out to figure out why that worked but nothing else does. And removing the noUnload option still lets it run fine, removing the logfile option is what marks the border between working and not working. Now the only question I have is why? Haha But thanks for the help eDave!
  • DE202408202727
    The artwork utility will always create a log (unlike some utilities). Unless you tell the axlRunBatchDBProgram command what this log file is named I guess you will get an error. In this case the log file has the fixed name "photoplot.log".
