  3. Using SKILL to draw over the PCB design
  • Views 15821
SergeiR
SergeiR over 10 years ago
Hello, I'm new to Allegro and SKILL, and am currently looking into using SKILL scripts to draw graphics over the board design.  I've looked at the example script included with Allegro (axlform.il), where the axlGRPDrw* functions are used to draw on a separate form, but have not been able to modify that code to draw in the main view.  So, I was wondering if what I am trying to do is possible, and if so where could I find some documentation and/or examples on how to do this.
-Sergei
  • B Bruekers
    B Bruekers over 10 years ago
    I am not sure about what you want to achieve here, do you want to draw something permanently on the screen or something that is (temporarily) attached to the cursor?
    For something attached to the cursor take a look at "Dynamic Cursor Examples" in the Allegro Skill documentation. (<cdsroot>/doc/algroskill)
    If you want to create lines, arcs, shapes etc then you need to look at the axlDBCreate* functions, like axlDBCreateLine, axlDBCreateCircle etc.
    Bram
  • SergeiR
    Thank you for the clarification.  I did want to draw on the screen (not attached to the cursor), but I also wanted to be able to remove these graphics at some point.  It seemed that if I use the axlDBCreate* functions, it may be difficult to separate these graphics from the rest of the design.  However, if that is the only way to draw (semi-permanently) over the design, I'm guessing I'll need to draw using axlDBCreate* on a specific layer, which could then be cleared entirely or just deleted...
  • B Bruekers
    What you need to then is to keep a list of the newly created items. Each axlDBCreate function returns a list of dbID. Add these ID's to a list and once you stop the function you can delete them with axlDeleteObject.
    So something like:
    ; make a new list
    l_items = list(nil)
    ;add items with nconc. 'appends' a list to a list, but changes the l_items destructively)
    nconc( l_items  car(axlDBCreateLine( (list 1:1 5:5), 1, "etch/top")) )
    nconc( l_items  car(axlDBCreateLine( (list 10:10 20:20), 1, "etch/top")) )
    ;remove any 'nil' items
    remdq(nil l_items)
    ;now the l_items contains the newly created dbID's. You can delete them
    axlDeleteObject(l_items)
