  3. setting rule on a constraint region?
  • Views 15919
jwhend
jwhend over 10 years ago
Hi All,
I want to set the shape to pin spacing for a constraint region. Is there away to access a specific region and change the setting?
 Jerry
  • Soundman99
    Soundman99 over 10 years ago
    Jerry, are you asking in general or specifically from Skill?  I don't know about skill for sure but in general, you should see 4 woorkbooks under the Spacing area (Spacing Constraint Set, Net, Net Class-Class and Region).  Under Region, you then can set the specific shape to pin spacing that you want on the appropriate tabs.
    You should be able to do it though, after a quick search, it should be something along the lines of
    tbl = axlCnsClassTableCreate("VOLTAGE" nil "ANALOG" 'spacing "25MILS")
    where VOLTAGE defines a Net Class-Class, ANALOG is your region and 25MILS is your Spacing Constraint Set.
    I think you have to define the spacing constraint set first,a and just assign that to the region, you can't directly edit the constraints within the region.
  • jwhend
    Specifically in skill. I've created a skill program that creates MFG coupon symbols which requires -1 spacing for pin to shape. I create are region, but currently the designers need to go into CM and update the shape to pin spacing to -1. I would like to do this programmatically.
    There is not a CLASS, so I am not sure if axlCnsClassTableCreate() will work.
    Thanks for your input and I will look at axlCnsClassTableCreate() some more.
    --Jerry
