  3. Run Command prompt using axlRunBatchDBProgram
  • Views 15504
Laiedz
Laiedz over 10 years ago
  • DE202408202727
    DE202408202727 over 10 years ago
    Try something like this:
    axlRunBatchDBProgram("xls2xml", sprintf(nil, "cmd /c %s", batchFile), ?noUnload t, ?silent t, ?noProgress t)
    Where the batchFile is the name of a batch file where you run your commands (cscript xls2xml.vbs "D:/TEST.xls")
  • Laiedz
    Thanks Dave! I already solved it with this line shell("CMD /c D:/xls2xml.vbs D:/TEST.xls"). But I will also try your suggestion. Thanks.. ^^
