  3. Delete layer using SKILL
  • Views 17085
Hassan122
Hassan122 over 10 years ago
Hi All,
Newbie here, is there a way to delete a user defined etch layer using SKILL if it has objects(route keepouts part of symdef) present in symbol definition? I have deleted these route keepouts from the layer I want to delete but since the component dra has the layer to be deleted it doesn't allow me to delete the layer.
  • DE202408202727
    DE202408202727 over 10 years ago
    It's just as difficult to remove an etch layer using Skill as it is using the menu options. If your layer is in the symbol definition you will probably have to remove the symbol first.
  • Hassan122
    Can we extract a list of symbols defined in a specific layer using SKILL?
  • DE202408202727
    I guess you could do something like this:
    layer = "ETCH/USER"
    setof(symDef, axlDBGetDesign() ->symdefs, exists(obj symDef ->children, obj ->layer == layer) || exists(pin, symDef ->pins, exists(pad, pin ->pads, pad ->layer == layer)))
