  3. Allegro crashes opening a new design after Skill routine...
  • Views 18187
Allegro crashes opening a new design after Skill routine uses axlEnterPoint
joma
joma over 10 years ago
Hi, I have written a routine to output the min track, gap and annular ring values etc which works ok. It will happily update text on drawing layers if they exist already. If the text does not exist the user is prompted for a position for the new data. This is where the problem starts. All seems ok and the design checks out and can be saved. However, if I try to open another design Allegro crashes and creates a .sav file in the directory of the other design or symbol. Just to be clear, there is never a problem if the text to be updated is alredy in the design, only when there is a prompt for position. Here is a snippet:
layer_count = length(axlGetParam("paramLayerGroup:etch")->groupMembers)
l_text = axlGetSelSet()
        foreach(text_t l_text
                when(text_t->text
                    if(rexMatchp("^Number of LAYERS.*$" text_t->text) ; Lower case writing on is on layer Outline.
                    then
                    layno_xy = text_t->xy
                    layCountText = sprintf(nil, "%n", layer_count )
                    newText = strcat("Number of LAYERS:", " ", layCountText )
                    replaceText(text_t newText)
                        ) ;end if
                    ) ; when
                ) ; end foreach
                        unless(layno_xy
                            axlSetActiveLayer("DRAWING FORMAT/DRILL")
                            axlVisibleDesign(nil)  axlUIWUpdate(nil)
                            axlVisibleLayer("DRAWING FORMAT/DRILL" t)
                            axlVisibleUpdate(t)
                            axlClearSelSet() axlAddSelectAll()
                                    when(text_t->text
                                        if(rexMatchp("^NUMBER OF LAYERS.*$" text_t->text)
                                        then
                                        textOrientNumLayDrill = axlTextOrientationCopy(text_t)
                                        axlDeleteObject(text_t)
                                            ) ; end if
                                        ) ; when
                                     ) ; end foreach
                                unless(layno_xy
                                    layno_xy = axlEnterPoint(?prompts list("Pick Number of layers TEXT POSITION:"))
                                    textOrientNumLayDrill = defaultOrient
                                    ) ; end unless
                             ) ; end unless
                    when( textOrientNumLayDrill
                 axlDBCreateText(sprintf(nil "NUMBER OF LAYERS: %n" layer_count), layno_xy,
                                                textOrientNumLayDrill, "DRAWING FORMAT/DRILL", nil)
                        ) ; when
Any ideas ?
Jim O'Mahony
  • DE202408202727
    DE202408202727 over 10 years ago
    Try registering your calling command as "interactive".
    Also, be careful naming functions with lowercase first letters (replaceText). Cadence gives no guarantee that there won't be a conflict with internal commands. Name it something like ST_replaceText. Ensure that you have no memory leaks - declare all your variables and check the code using sklint.
  • joma
    Ok, thanks Dave, I renamed all functions and put all variables inside let() commands. I can't check with sklint as I do not have the skill toolbox.
    My problem is that when I call the command as interactive it throws up another problem with the script calls that create the reports
    that the routine is based on (W-Cannot exit current application). I could create the reports with another skill file except for the one
    that writes the drcs. That needs to be done after the metal to metal rules are changed temporarily and before they are changed back
    again. I would attach a .zip of the file but the attach icon is greyed out.
  • DE202408202727
    Ah. Yes I try to avoid scripts inside Skill routines.
    Try sklint, you might be surprised.
  • joma
    I would love to try sklint but unfortunately we don't have it and I don't see my company paying for a licence.
    I think axlExtractToFile() with the view drc_rep will get me the drc report but I will have to search for how to create
    a view that will give me something similar to the "Etch Detailed Length Report" that I am using.
  • DE202408202727
    Try typing sklint(?file [your skill filename]) on the Skill command line.
    You can find all the Metal-Metal drcs by using the command:
    drcs = setof(obj, axlDBGetDesign() ->drcs, obj ->name == "Minimum Metal Spacing")
    From this list you can produce your own report:
    outPort = axlDMOpenFile("MISC", "drcReport.txt", "w")
    foreach(drc, drcs, fprintf(outPort, "%L Layer: %s, Expected: %s, Actual:%s\n", drc ->xy, drc ->layer, drc ->expectd, drc ->actual))
    axlDMClose(outPort)
    axlUIViewFileCreate("drcReport.txt", "drcs", nil)
