  3. Swapping elements in a list
  • Views 16132
EvanShultz
EvanShultz over 10 years ago
I need to receive a list and then reverse two elements in the list. Not finding a good way to do it with the included SKILL functions (though I could have just missed it), I wrote my own. Here it is (as usual, sorry for the lack of formatting):
; swaps element at given index with following element in list
; parameters:
; swap_index: index of film to move [integer]
; input_list: list to be modified [list]
; returns: input_list with swapped elements [list]
procedure(swap_next(swap_index input_list)
   let((j final_list)
      setq(j 0) ; need external counter in for loop variable auto-increments
      ; run through input list and either grab the current element or swap the next two
      for(i 0 (length(input_list) - 2)
         if(j == swap_index then
            ; at the index to swap, dump next element and then current element into output list
            final_list = cons(nth((j + 1) input_list) final_list)
            final_list = cons(nth(j input_list) final_list)
            j++ ; increment counter since we grabbed two elements
         else
            ; for any other index, just copy the input list to output list
         j++
      reverse(final_list) ; return reversed list since it was built "backwards"
This works, but it's awfully complicated. Since I don't have direct access to the auto-incrementing loop variable, I created my own. It seemed more complicated to use foreach() than this, but I'm a hardware guy who likes to think he can write a bit of code. I wouldn't be surprised if there's an obvious way to do it and I'm just daft for overlooking it.
Thanks in advance for any advice.
  • DE202408202727
    DE202408202727 over 10 years ago
    I think this would be better processed as an array (maybe use listToVector) but this might work for you:
    nconc(reverse(constar(nth(swap_index, input_list), nth(swap_index + 1, input_list), nthcdr(length(lst) - swap_index + 1, reverse(input_list)))) nthcdr(swap_index + 2, input_list))
    Using an array:
    v = listToVector(input_list)
    x = v[swap_index]
    v[swap_index] = v[swap_index + 1]
    v[swap_index + 1] = x
    vectorToList(v)
    A Lisp expert might me able to provide more elegant solutions.
  • jwhend
    jwhend over 10 years ago
