  3. Accepting user input with wildcards (regex help)
  • Views 17482
EvanShultz
EvanShultz over 10 years ago
I want to accept user input that contains wildcards for ref des and net names. The basic solution isn't difficult and I get good results with:
; build regular expression pattern of filter text
; put start and end anchors on text and all asterisks match "any character zero or more times"
rexCompile(buildString(parseString(strcat("^" "input_string" "$") "*") ".*"))
(I know I can use the PCRE functions, but I started with the basic ones since they worked.)
Trouble came when I tried to find pathological cases and realized that regex special chars are common in net names (especially "+" like in "+5V"). Some regex special chars are ".\*+^$".
Starting with the first problem I encountered, I was able to modify the following code to handle a plus sign:
pat = pcreCompile("[\\+]")
rexCompile(buildString(parseString(strcat("^" pcreReplace(pat "input_string" "\\\\+" 0) "$") "*") ".*"))
This does work and I can then accept an asterisk as a wildcard on the input and match "+5V", "+3.3V", etc. in my net names. But this is just one of the special chars. As the special chars could be in any position of the input string (ref des or net name), I don't see any one regex pattern to handle it all and doing them individually looks miserable. There must be a better way which I don't see. Searching on the forums and reading sklangref again haven't lit a bulb over my head, but it may be because I'm just daft.
Moving through the string character-by-character and replacing special chars with escaped versions would be an option, but that's rather painful and sure to incur a delay that users would notice on a big design (I tried using axlDBCloak while comparing the input string to the regex and didn't see a speed up, possibly because I'm only doing a database read?). The "Find by Name or Property" form does the same thing but query results appear instantly. It even handles multiple wildcards properly, so there's a way to do it well but I haven't figured it out. Can anyone help?
  • EvanShultz
    I was able to make a workable solution, though as ugly as I feared in my post above, by iterating through the input char string. Here's what I have:
    searchString = ""
    for(i 0 (strlen(QSC_fnData->filter) - 1)
    char = substring(QSC_fnData->filter (i + 1) 1)
    if(nindex(".*+^$" char) then
    if((char == "*") then
    searchString = strcat(searchString ".*")
    else
    searchString = strcat(searchString "\\" char)
    else
    searchString = strcat(searchString char)
    rePattern = pcreCompile(strcat("^" searchString "$"))
    Basically I'm treating "*" differently from other special chars by making it a "any char 0 or more times" in the regex while any other special char just gets escaped so that it's an exact match, and then any other char just gets passed through. (Note that I will keep experimenting as I'm not sure the special chars are properly inclusive).
    I still have a feeling that this could be better. The input can be sanitized this way, and it's more robust than the above, but it looks ugly. Are there better methods?
    (Also, responsiveness begins to degrade with designs having more than about 500 nets. Somehow there must be a faster way to do it as I mentioned above that the Find by Name or Property form is immediate even with >2000 nets. Any ideas on how to make iterating through a list while performing pcreExecute on each list member, or a totally different method, would also be appreciated.)
  • B Bruekers
    B Bruekers over 10 years ago
    2 things,
    i would do a parse string on the search string, convert it and then replace the regex characters with something else. Place them in a new list and build the list again. The resulting string is then the search string.
    l_str = parseString("+sdrsf*" "")
    new_str = nil
    while(l_str
    str=car(l_str)
    l_str=cdr(l_str)
      case(str
      ("+" push(".+" new_str))
      ("*" push(".*" new_str))
      (t push(str new_str))
    new_str= buildString(new_str "")
    pp(new_str)
    2nd, if you first make an assoc list of the nets (netname net dbID) then you can use the pcreMatchAssocList to do a complete match of the lists of nets. This runs fast on my PC.
    l_assocNet= mapcar( lambda((item) list(item->name item)) axlDBGetDesign()->nets)
    pcre= pcreCompile(".*3V.*" 1)
    l_nets= pcreMatchAssocList(pcre l_assocNet)
    The '1' in the pcreComplie is to ignore case sensitive.
    The l_nets contains an assoc list, like:
    ("+3V3" dbid:394326552)
    ("3V3_FB" dbid:394326384)
    ("3V3_COMP" dbid:394326272)
    To keep only the dbid's you can do a mapcar:
    l_nets= mapcar('cadr l_nets)
  • EvanShultz
    Thanks for the help!
    I ended up doing this:
    ; sanitize input field for use as a regex, going character-by-character through the input
    searchString = ""
    foreach(char parseString(QSC_fnData->filter "")
    ; char is either a wildcard which is converted for the regex, a regex special char that is escapted, or passed through
    cond(
    ((char == "*") searchString = strcat(searchString ".*"))
    (stringp(index("^.$|()[]+?" char)) searchString = strcat(searchString "\\" char))
    (t searchString = strcat(searchString char))
    ; put start and end anchors on search string built above
    ; generate assoc list of all nets then regex pattern match for search string, resulting in a list of matching net names
    NetList = mapcar('cadr rexMatchAssocList(strcat("^" searchString "$") mapcar(lambda((item) list(item->name item)) axlDBGetDesign()->nets)))
