  3. setting all spacing constraints values to same value with...
  • Views 14843
setting all spacing constraints values to same value with axlCNSSetSpacing
Ejlersen
Ejlersen over 10 years ago
Hi
Working with axlCNSSetSpacing I don't seem to be able to find a way to specify the same value for all constraint types.
I hope someone has an suggestion to do this?
I would like to avoid creating the large list that contain all constraint types with the same value.
Best regards
Ole
  • fxffxf
    fxffxf over 10 years ago
    try the following skill code, if you don't want any items you would need to remove them from this list
    a = axlCNSGetSpacing(nil nil nil)
    b = nil
    defaultSpace = 10.0
    foreach( i a
       b = cons(list(i defaultSpace) b)
  • Ejlersen
    Hi
    Yes, thanks - this is exactly the way I do it today but was not sure if there was an even more optimzed way to do this.
    Did try with 'all but that was not accepted.
    Best regards
    Ole
