  3. Find a Angle
  • Views 18096
Find a Angle
Soundar1984
Soundar1984 over 10 years ago
Hi everyone, I need to know how to find an angle of Cline segs.
I tried to find angle for Single Cline Segment using this method.
angle=atan2( (y2-y1) / (x2-x1) ) * (180 / 3.14)
When i compare my calculated angle value of cline segs with the value of  Normalize angle property of  cline segs.
There is huge  difference in my calculated angle value and system calculating angle value.
Normalize angle is angle measured by cadence tool and it will be shown Show Element Dialog.(Click Display Menu ->Select Element option , enable cline segs in find filter and then click on the clinesegs in the design it will show all the properties including angle property of the selected cline segs)
Please help me  to calculate the angle value manually that must be equal to system calculating angle value.
Skill User
  • DE202408202727
    DE202408202727 over 10 years ago
    angle = axlRadToDeg(atan2(dy, dx))
    when(negativep(angle), angle = 90 + angle)
  • Soundar1984
    Thanks eDave. This method working correctly but  for some values  dx ,dy  it not calculating correctly. Please see the values below,
    Skill > angle=axlRadToDeg(atan2(-261.21,-261.21))
    -135.0
    Skill> when(negativep(angle),angle=90+angle)
    -45.0 Correct Answer = +45.0 degrees
     Skill > angle=axlRadToDeg(atan2(28.84,-4.18))
    98.24688
    Nil
    Skill>angle
    98.24688 Correct Answer = +8.247 degrees
  • Soundar1984
    The below code calculating angle correctly thank u edave for your help,
    linePts=car(axlGetSelSet())->startEnd
    DxDy=axlMXYSub(cadr(linePts),car(linePts) )
    Dx=car(DxDy)
    Dy= cadr(DxDy)
    m=Dy/Dx
    ;Replaced atan2 by atan
    angle=axlRadToDeg( atan(m) )
    when(negativep(angle),angle=angle+90)
