  3. Arc Routing - SKILL for Checking
  • Views 777
Vkmouli
Vkmouli over 9 years ago
Any skill code available to check layer by layer which was routed using ARC ROUTING?.
That is If both ARC routing and normal routing is used in same layer, then can i run a skill code to check whether arc  section contains any tracks which is not in arc.
Or else can i give a number signals which is to be routed as ARC..
