  3. Need to generate the stacked via reports ( L1_L3 ).
  • Views 20717
krthik15
krthik15 over 9 years ago
Dear all,
I want to be generate the stacked via reports ( L1_L3 ).
Actually i have created two vias like L1-L2 and L2-L3. In some places in design stacked L1-L2 and L2-L3 vias .Need to be  generate those stacked via reports.
netname    stacked via location     stacked via count      padstack name
Please share if anyone have skill code
-Karthik.k
  • Kirti Sikri
    Kirti Sikri over 9 years ago
    COS article on Using SKILL code for Stacked Vias along with the code can be found on COS at  Working with Stacked Vias Using Allegro SKILL
    Hope it helps
  • krthik15
    Thanks Kirti Sikri!
  • mstaub
    mstaub over 6 years ago in reply to Kirti Sikri
    There is a fundamental flaw with the code in Working with Stacked Vias Using Allegro SKILL. This code creates a table of stacked vias based on xy location and doesn't pay any attention to net/layer span. For example, If I have a 1:4 GND via located at xy 1,1 and a 5:10 Power via located at the same xy of 1,1, this code stores these two vias as just 1 stacked via. If I then use this table to do any further analysis of the via stacks, I will be using incorrect data. Theis gets even worse if you have 4 via stacks, all with different nets, sharing the same XY, which is very possible in HDI designs.
    You are better off looking at the layer span of the via stack when by using axlDBViaStack() . By using this function you can get a list of all the vias in the stack and through some logic can determine what the layer span is. For example, using the vias from my previous example my new table keys might be something like "1.000,1.000_1-4" and "1.000,1.000_5-10" rather than Cadence's example which only stores one key of (1.000 1.000). You can further make stronger keys by adding net names to the key strings as well.
    I have tested this and can provide example code if needed.
  • cdlep
    cdlep over 6 years ago in reply to mstaub
    Hi Mstaub,  I would be interested in taking a look at your example code If you don't mind.  I just finished writing a painful function to do this after playing with Working with Stacked Vias Using Allegro SKILL and  just opened the forum to see you mention  axlDBViaStack().
  • mstaub
    mstaub over 6 years ago in reply to cdlep
    Hi cdlep,
    I'll attached both a screenshot and the skill file of a stripped down version of the code I wrote. I made some dummy board files and did some preliminary testing on them, and everything seems to check out. I also ran this on a design with over 100K vias.
    One thing to note is that I am storing custom via structures in the table which include the vias net name, layer span, xy location and via dbids. This can easily be modified to whatever suites your needs.
    Here is a picture of the code, which is a little more readable from my dev environment than just pasting the code directly in the comment.
    Attaching skill file for reference.
    Please let me know what you think of this.
