  3. file exported from axlGetAttachment() not the same as the...
  • Subscribers 163
  • Views 13783
file exported from axlGetAttachment() not the same as the original imported file
DavidJHutchins
DavidJHutchins over 9 years ago
In Allegro:
Command > skill
Skill > axlCreateAttachment( "test_attach" nil 0 'file "test.log")
attachment:120983576
Skill > file=axlGetAttachment( "test_attach" 'file)
attachment:120983840
Skill > file->??
(id "test_attach" size 177 revision
    0 password nil timeStamp 1487005612
    data "C:/Users/davidh/AppData/Local/Temp/#Taaaaab06968.tmp" objType "attachment" dataFormat
    file
Skill > axlOSBackSlash(file->data)
"C:\\Users\\davidh\\AppData\\Local\\Temp\\#Taaaaab06968.tmp"
Skill > exit
t
Command >
At the OS level:
C:\Users\davidh\Downloads>wc test.log
  4   9 176 test.log
C:\Users\davidh\Downloads>od -c test.log
0000000   (   -   -   -   -   -   -   -   -   -   -   -   -   -   -   -
0000020   -   -   -   -   -   -   -   -   -   -   -   -   -   -   -   -
0000100   -   -   -   -   -   -   )  \n   D   e   s   i   g   n       f
0000120   i   l   e   :       C   :   /   U   s   e   r   s   /   d   a
0000140   v   i   d   h   /   D   o   w   n   l   o   a   d   s   /   Q
0000160   F   S   -   0   2   6   -   0   4   _   2   5   -   X   X   -
0000200   D   -   P   T   4   .   d   r   a  \n   E   x   p   o   r   t
0000220       u   n   i   t   s   :       I   n   c   h  \n   s   t   e
0000240   p   _   o   u   t       c   o   m   p   l   e   t   e   .  \n
0000260
C:\Users\davidh\Downloads>copy C:\\Users\\davidh\\AppData\\Local\\Temp\\#Taaaaab06968.tmp test.txt
        1 file(s) copied.
C:\Users\davidh\Downloads>wc test.txt
  4   9 177 test.txt
C:\Users\davidh\Downloads>od -c test.txt
0000260  \0
0000261
C:\Users\davidh\Downloads>diff -ibw test.log test.txt
Binary files test.log and test.txt differ
