  3. Accessing General Parameter of Artwork Tab
  • Subscribers 163
  • Views 16288
kumarsanj
kumarsanj over 9 years ago
Is there a skill AXL function to access the general parameter tab of artwork window shown below.
Thank you
Sanjeev
  • DavidJHutchins
    DavidJHutchins over 9 years ago
    I don't think any such functions exist, most of those values are written to the 'art_param.txt' file that is read by the 'artwork' external command for file generation
  • jwhend
    jwhend over 9 years ago
    If you are looking to get the params, you can use  axlGetParam("artwork:filmfilename")
    To create a film record, use axlFilmCreate.
    If you are trying to change a parameter, you might need to grab the current params, delete the film record and add it back in with the changes.
    You can delete a film record with axlDeleteObject("artwork:filmfilename")
  • kumarsanj
    Thank you for the response.
  • kumarsanj
    Thank you jwhend. Actually I was looking for accessing the window as shown in the above Pic. However looks like there is no AXL function as David says the same.
