  3. Skill for removing voids?
  • Views 18845
Olli
Olli over 9 years ago
Has anyone written a skill script to remove shape voids in a design?
I can't figure out how to select the voids on a regular macro but it should be possible in SKILL.
  • Olli
    This is my best effort with regards to a regular script. "Drag_start" and "drag_stop" are not documented and I've noticed that changing the numbers tends to make the script fail. Originally that comes from macro recorder of course.
    The script kills (most) voids for whatever shape is under the cursor at the time.
    Allegro script
    # start time: Wed Sep 28 11:27:52 2016
    # Version: 17.2-2016 S005 (v17-2-50AQ) Windows SPB 64-bit Edition
    version 17.2
    #setwindow pcb
    trapsize 599
    shapeedit
    shape void delete
    pick_to_grid -cursor
    # Macro file: coordinates are relative to pick on replay.
    #pick_origin
    drag_start rel grid -112.155 86.513
    drag_stop rel 235.813 -148.821
    pick rel grid 0 0
    #prepopup rel 0.000 0.000
    done
    #shapeedit
    # stop time: Wed Sep 28 11:28:26 2016
  • DavidJHutchins
    DavidJHutchins over 9 years ago
    here is some simple skill code that should delete all the voids in a design:
    procedure(delete_voids()
        let((o_shape)
            (axlClearSelSet)
            (axlSetFindFilter ?enabled list("noall" "voids" "INVISIBLE") ?onButtons list("noall" "voids"))
            axlAddSelectAll()
            foreach(void axlGetSelSet()
                (o_shape = axlDBOpenShape(void->parent nil))
                axlShapeDeleteVoids(void)
                axlDBCreateCloseShape(o_shape)
    axlCmdRegister("delete_voids" 'delete_voids ?cmdType "general")
  • Olli
    This crashes 17.2 S015 when I run it. Does this have requirements i.e. need to be in specific mode or something?
  • DavidJHutchins
    it runs without any issues for me in 16.6 and 17.2 S018
  • Olli
    That's how it sometimes is. Thanks anyways, I went back to S015 because they broke step models in 3D viewer..
