  3. Detect if form is already being displayed
  • Views 15655
khuranav007
khuranav007 over 9 years ago
Hello, I have an Allegro Skill script that is invoked using a custom menu pick.  The skill script displays a form.  Problem is I don't know how to stop the form from displaying again when the user selects the menu pick.  Is there a built-in function that can be used to check to see if form is already being displayed?  If not, any other ideas?  Thanks for help!
  • DE202408202727
    DE202408202727 over 9 years ago
    This is how I do it:
    defun( xxxx ()
     prog((xxxx)
      when(boundp('my_form) && axlIsFormType(my_form) && axlUIWExpose(my_form), return())
      defvar(my_form)
  • khuranav007
    Thanks Dave. Can you please explain what these lines are doing? And, this is part of the same Skill script that invokes the form...?
  • DE202408202727
    I just showed the defun and prog lines to show that you need to include the lines in a prog loop to be able to use return(). You can, of course, exit more cleanly than this if you object to using return().
    declaring myForm as global using defvar ensures that you can detect if it's called later.
    boundp('my_form) tells you whether the form has been used before in this session.
    axlIsFormType(my_form) tells you whether the form is still active (it will be nil if not).
    If it is active, axlUIWExpose(my_form) exposes the form and return() exits the function.
  • khuranav007
    Thanks Dave - appreciate the help very much.
