  3. Replay .SCR file in command window
  • Subscribers 163
  • Views 16804
kumarsanj
kumarsanj over 9 years ago
Hi All,
I am trying to create .SCR file and replay it. Below are the program for the same.
(defun DREND ()
          Script_File=outfile("DRILL_LEGEND.scr" "w")
          fprintf(Script_File "setwindow pcb\n")
          fprintf(Script_File "trapsize 9237\n")
          fprintf(Script_File "generaledit\n")
          fprintf(Script_File "delete\n")
          fprintf(Script_File "setwindow form.find\n")
          fprintf(Script_File "FORM find all_on\n")
          fprintf(Script_File "drag_start grid 6573.11 -3787.21\n")
          fprintf(Script_File "drag_stop 13408.81 -8165.76\n")
          fprintf(Script_File "prepopup 14018.49 -5837.93\n")
          fprintf(Script_File "done\n")
          close(Script_File)
          axlShell("replay DRILL_LEGEND.scr")
); end DREND
axlCmdRegister( "DREND" `DREND)
Once I run the program below error pops up in command window. Can someone guide me where I am doing mistake?
W- Cannot exit current application
E- No command active
Sanjeev
  • DavidJHutchins
    DavidJHutchins over 9 years ago +1
    I got your code to work by changing the last line: axlCmdRegister( "DREND" 'DREND ?cmdType "general")
  • DavidJHutchins
  • kumarsanj
    Thank you David, it works perfectly fine.
