  3. how to group the net objTypes?
  • Subscribers 158
  • Views 14961
krthik15
krthik15 over 8 years ago
I'm trying to individually group the via,pin,shape and path of the net . but its not working. it shows E- *Error* eval: unbound variable - shapes
axlSetFindFilter(?enabled "Nets" ?onButtons "Nets")
axlSelect()
net_db = axlGetSelSet()
net = car(net_db)
foreach(branch, net ->branches, foreach(child, branch ->children, when(child ->objType == "via",vias= cons(child, vias)), when(child ->objType == "pin", pins= cons(child, pins)), when(child ->objType == "shape", shapes= cons(child, shapes)),when(child ->objType == "path", paths= cons(child, paths)) ))
Karthik.k
  • DavidJHutchins
    DavidJHutchins over 8 years ago
    I added local variable definitions in a let(() statement & don't get that error:
    procedure(test_code()
    let((net_db net vias shapes pins paths)
    (axlSetFindFilter ?enabled "Nets" ?onButtons "Nets")
    (axlSelect)
    (net_db = (axlGetSelSet))
    (net = car(net_db))
    foreach(branch
    (net->branches)
    foreach(child
    (branch->children)
    when(((child->objType) == "via")
    (vias = cons(child vias))
    when(((child->objType) == "pin")
    (pins = cons(child pins))
    when(((child->objType) == "shape")
    (shapes = cons(child shapes))
    when(((child->objType) == "path")
    (paths = cons(child paths))
  • krthik15
    David Hutchins,
    Thanks for the reply.
    I have run your code still i get errors
    Skill > load("test.il")
    t
    Skill > test_code
    Enter selection point
    last pick: -7254.751 4315.883
    (dbid:235427968)
    Skill > vias
    E- *Error* toplevel: undefined variable - vias
    nil
    Skill > paths
    E- *Error* toplevel: undefined variable - paths
    nil
    Skill > pins
    E- *Error* toplevel: undefined variable - pins
    nil
    Skill > shapes
    E- *Error* toplevel: undefined variable - shapes
    nil
    Karthik.K
  • Kirti Sikri
    Kirti Sikri over 8 years ago
    It's because you are appending to list of objects before declaring it in the following line.
    Add this before foreach and code will work fine
    pins=()
    vias=()
    shapes=()
    paths=()
    You can also declare pins=nil etc.
    Kirti
  • krthik15
    Kirti,
    Still it shows same error. Attached my code here.https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/test_5F00_code.il
    Note : I'm working in APD 16.6
    Skill > load("test_code.il")
    t
    Skill > _testcode
    last pick:  -6290.000 4480.000
    (dbid:228070032 dbid:228070008 dbid:227184192 dbid:228173648)
    Skill > vias
    nil
    Skill > shapes
    nil
    Skill > pins
    nil
    Skill > paths
    nil
    Skill >
  • Kirti Sikri
    Its because vias , paths etc have been defined as local variables in function _testcode() using let as shown in excerpt below.
    So they cannot be accessed from outside the function.
    procedure( _testcode()
    let( (net_db net vias pins shapes paths )
    To access vias , paths from outside define the variables before procedure definition and remove from inside the function.
    pins=()
    vias=()
    shapes=()
    paths=()
    let( (net_db net )
    Kirti
