  3. Calling printf inside axlShell
  • Replies 7
  • Views 18424
kumarsanj
kumarsanj over 9 years ago
Is it possible to call printf function inside the AXLShell?
Sanjeev
  • DavidJHutchins
    DavidJHutchins over 9 years ago
    Command > skill 'printf("this is a test")'
    this is a test
    t
    Command > skill 'axlShell "(printf `\"this is a test2`\")" '
    this is a test2`
    t
    t
    Command >
  • kumarsanj
    David,
    Thanks for responding to this query.
    Actually i am trying to do something as below
    Board_name=axlGetDrawingName()
    axlShell("artwork")
    axlShell("setwindow form.film_control")
    axlShell("FORM film_control filename_prefix fprintf( %s\n", Board_name))
    However looks like it doesnot allow the above fprintf function inside of the axlShell command.
    Could you please help me for the above logic? How can I call Board_name after "axlShell("FORM film_control filename_prefix"
    Sanjeev
  • DavidJHutchins
    You might want to try the following:
    skill 'axlShell(strcat("FORM film_control filename_prefix " (axlCurrentDesign) "_"))'
    I used (axlCurrentDesign) since it only returns the base filename, axlGetDrawingName() returns the full pathname
  • kumarsanj
    Excellent David.
    This is what I was looking for.
    Thank you very much.
    Sanjeev
  • kumarsanj
    David I have One more query.
    I want to set the Format of ARTWORK-->General parameter tab as below.
    Integer place to 5 and
    Decimal place to 5.
    And below is the code for the same.
    axlShell("artwork")
    axlShell("FORM film_control format_dec_places 5.0")
    axlShell("FORM film_control format_int_places 5.0")
    But it doesn't set the value as required.
    Do you have any idea on this?
    Thank you.
    Sanjeev
