  3. How to find if Padstack is used or not?
  • Subscribers 163
  • Views 15700
Kirti Sikri
Kirti Sikri over 9 years ago
How to find if the padstack in a design is used or not using Allegro Skill?
Kirti
  • DavidJHutchins
    DavidJHutchins over 9 years ago
    Below is a simple skill procedure that counts the padstack usage on symbol definitions & nets, then reports any padstacks that are not used
    procedure(PadStackUsage()
        let((PadTable)
            (PadTable = makeTable("PadTable" nil))
            foreach(pad ((axlDBGetDesign)->padstacks)
                (PadTable[pad->name] = 0)
            foreach(symdef (axlDBGetDesign()->symdefs)
                foreach( pin symdef->pins
                    (PadTable[pin->name] = add1(PadTable[pin->name]))
            foreach(net ((axlDBGetDesign)->nets)
                foreach(branch (net->branches)
                    foreach(child (branch->children)
                        if(((child->objType) == "pin") || ((child->objType) == "via") then
                            (PadTable[child->name] = add1(PadTable[child->name]))
            foreach(name PadTable
                when(eq(PadTable[name] 0) axlMsgPut("padstack %s not used" name))
                remove(name PadTable)
  • Kirti Sikri
    Thanks.
    A question why do we have to use symdef->pins and then pins which are on nets?
    I had programmatically created a new padstack(using make_axlPadstack) which is not on net or part of symbol definition.
    Hence this code was not able to find those padstacks.
    I used following code
    ;checks if given incheckPadstackName  is to be checked for usage or all padstacks
    (defun allpadstacks (@optional (incheckPadstackName nil))
    (let (vis_list pin_list padstacklist pad_name noDBId key)
    vis_list = axlVisibleGet()
    axlVisibleDesign(nil)
    axlVisibleLayer("PIN" t)
    axlVisibleLayer("VIA CLASS" t)
    axlClearSelSet()
    axlSetFindFilter(?enabled list("noall" "pins" "vias")
    ?onButtons list("noall" "pins" "vias"))
    axlAddSelectAll()
    pin_list = axlGetSelSet()
    axlVisibleSet(vis_list) ;restore design visibility
    axlVisibleUpdate(t)
    axlClearSelSet()
    padstacklist=makeTable("atable1" nil)
    foreach(pin_db pin_list ;go thru layout pin list
    padstack_db = pin_db->definition ;Extract PadstackID from pinID
    pad_name=padstack_db->name ;Extract Padstack Name from PadstackID
    padstacklist[pad_name]=pad_name ;add to padstacklist table
    );end foreach
    (if incheckPadstackName && !padstacklist[incheckPadstackName] then
    printf("Padstack %L is not used\n" incheckPadstackName)
    else
    allPadstacks=axlDBGetDesign()->padstacks
    allPadstacksNameList=nil
    noDBId=nil
    (foreach curPadstack allPadstacks
    key=curPadstack->name
    if(!padstacklist[key] then
    printf("Adding key to noDBId %L\n" key)
    noDBId=cons(key noDBId)
    );let
    );end of defun allpadstacks
