  3. How to color a string using SKill
  • Replies 11
  • Subscribers 160
  • Views 18902
JerryWilson
JerryWilson over 8 years ago
Hi Dave, all
I have a code to check footprint prints in our library. In my code i will output it into a log file called MCL log file.
In the code i have pass/fail messages in which for pass messages, i want to color it green & fail message as red.
How do i do that. Below is a portion of the code.Hope anyone can help.
JerryWilson
defun( _mcl_start ()
let((errors overallerrors)
overallerrors=0
mcl_log.log=axlDMOpenLog("mcl")
fprintf(mcl_log.log " MCL CHECK LOG ............................... Created:")
Date=(getCurrentTime)
fprintf(mcl_log.log "%s\n\n" Date)
axlDBGetDesignUnits()
fprintf(mcl_log.log "\n-----------------------------CHECK DRAWING PARAMETERS----------------------------\n")
errors=0
let((y m p)
y = axlGetParam('paramDesign)
if(y->units=="millimeters" then
;fprintf(mcl_log.log "\nPASSED :USER UNITS." )
else
errors++
overallerrors++
fprintf(mcl_log.log "\nFAILED :INVALID USER UNITS., %s" y->units)
if(y->accuracy==3 then
;fprintf(mcl_log.log "\nPASSED :ACCURACY." )
else
errors++
overallerrors++
fprintf(mcl_log.log "\nFAILED :INVALID ACCURACY., %d" y->accuracy)
if(y->height==210 then
;fprintf(mcl_log.log "\nPASSED :DRAWING EXTENT HEIGHT." )
else
errors++
overallerrors++
fprintf(mcl_log.log "\nFAILED :INVALID DRAWING EXTENT HEIIGHT., %f" y->height)
if(y->width==297 then
;fprintf(mcl_log.log "\nPASSED :DRAWING EXTENT WIDTH." )
else
errors++
overallerrors++
fprintf(mcl_log.log "\nFAILED :INVALID DRAWING EXTENT WIDTH., %f" y->width)
if(y->xy==list(-150 -105) then
;fprintf(mcl_log.log "\nPASSED :DRAWING EXTENT LOWER X AND LOWER Y." )
else
errors++
overallerrors++
fprintf(mcl_log.log "\nFAILED :INVALID DRAWING EXTENT LOWER X AND LOWER Y., %P\n" y->xy)
m = axlDesignType(t)
if( or( m=="PACKAGE" m=="SHAPE" m=="FLASH" ) then
;fprintf(mcl_log.log "\nPASSED :SYMBOL TYPE., %s\n" m)
else
errors++
overallerrors++
fprintf(mcl_log.log "\nFAILED :INVALID SYMBOL TYPE., %s\n" m)
if(errors==0 then
fprintf(mcl_log.log "\n\t%d ERROR(S) ON DRAWING PARAMETERS SETTINGS.\n", errors)
else
fprintf(mcl_log.log "\n\t%d ERROR(S) ON DRAWING PARAMETERS SETTINGS\n", errors)
;fprintf(mcl_log.log "***CHECK DRAWING PARAMETERS-END*****\n\n")
  • eDave
    eDave over 8 years ago
    defun( _testHTML ()
    let((p)
    p = axlDMOpenFile("ALLEGRO_HTML", "aaa.log", "w")
    when(p
    fprintf(p, "<!DOCTYPE html>\n")
    fprintf(p, "<html>\n")
    fprintf(p, "<body>\n")
    fprintf(p, "The quick brown ...<Br>\n")
    fprintf(p, "<font color=\"red\">This is red text.</font>\n")
    fprintf(p, "</body>\n")
    fprintf(p, "</html>\n")
    drain(p)
    axlDMClose(p)
    axlUIViewFileCreate("aaa.log", "Sample", nil)
  • eDave
    Or just this:
    p = axlDMOpenLog("aaa")
    when(p
    fprintf(p, "The quick brown fox at (0.0 0.0) ...<Br>\n")
    drain(p)
    axlDMClose(p)
    axlUIViewFileCreate("aaa.log", "Sample2", nil)
  • JerryWilson
    Hi Dave
    Thanks So much. I have successfully added the color in my code. I was wondering if i can bold the fonts. Is a way to do it?
    Regards
    Jerry
  • eDave
    <b>This text is bold</b>
  • JerryWilson
    Hi Dave
    Thanks so much for your help. I have an issue now. I have updated my code & testing it in 16.6, it works perfectly fine. We are moving to 17.2 soon, & i was testing it in 17.2, to my surprise its not working at all.
    Any reason why. Here i captured how the message came out. Is there any extra command needs to be added. Please help.
    THIS IS HOW I ADDED IN THE FPRINTF
    fprintf(mcl_log.log "<b><font color=\"red\">\nFAILED :LINE WIDTH IN PACKAGE GEOMETRY/ASSEMBLY_TOP IS %.3f</font></b>" width)
    Below is the message, the whole command is being printed out.
    <b><font color="red">
    FAILED :LINE WIDTH IN PACKAGE GEOMETRY/ASSEMBLY_TOP IS 0.076</font></b><b><font color="red">
