  3. Concatenation of double quotes (")
  • Subscribers 163
  • Views 4690
kumarsanj
kumarsanj over 9 years ago
Hi All,
I want to run a shell command shown below
reports "Component Report" nographic write
As we know axlshell doesn't allow double quotes inside so I am trying to concatenate with strcat, however I am facing a problem with the double quotes. I also tried with \”, but unable to build a string as shown above. Does anyone have an idea, how can a double quotes can be concatenated in a string.
Sanjeev
  • DE202408202727
    DE202408202727 over 9 years ago
    sprintf(nil, "reports \"Component Report\" nographic write")
  • kumarsanj
    Thanks Dave for the response.
    Once we run the above command in skill window, below result popped up.
    Actually we should not get the slash symbol, however it appears in the result.
    Sanjeev
  • DE202408202727
    That is correct. This is just how the string is displayed.
  • kumarsanj
    Thanks Dave. It works fine once I run the axlshell command with your suggested answer.
    Sanjeev
