  3. Compare to different netlist
  • Views 14676
Laiedz
Laiedz over 9 years ago
Hi everyone,
I would like to ask some help, I created skill program that will determine if there are swap pins. But the problem is when I try to test two different netlist from two different board its not working.
I am using netlist from export.
  • DE202408202727
    DE202408202727 over 9 years ago
    Without seeing your code it is difficult to know what's not working.
    Try using extracta with the pinswap_rep.txt view file.
