  3. Accessing color
  • Views 16241
Accessing color
JerryWilson
JerryWilson over 8 years ago
Hi Dave
I tried to use a code you provided in one of the forum below in 17.2, i'm seeing errors
E- *Error* defun: too few arguments (at least 3 expected, 2 given) - (DE_setLayerColour (layer colour))
E- *Error* load: error while loading file - "L:/ecad_proj/MCLLIB_ZMY12_172/cjj082_adwlib/codes/col.il" at line 1
Tried reomoving the ")", seeing the error below. Am I missing something. Please Advice.
E- *Error* DE_setLayerColour: too few arguments (2 expected, 0 given) - nil
defun( DE_setLayerColour (layer, colour))
let((colourNo, colours, n, p)
cond(
(numberp(colour), colourNo = colour)
(!colour, nil)
(t
colours = '(
(White 255 255 255)
(LtBlue 014 210 255)
(Rose 255 121 203)
(Green 000 255 106)
(Purple 166 016 255)
(Teal 121 153 196)
(Red 255 000 000)
(Yellow 255 255 000)
(Blue 000 000 255)
(Aqua 055 247 215)
(Gray 179 179 185)
(Olive 116 196 143)
(Orange 252 199 046)
(Pink 255 178 255)
(Beige 172 138 138)
(Navy 002 168 213)
(Violet 176 000 206)
(Gold 234 190 000)
(Silver 217 224 224)
(Rust 242 127 134)
(Lime 014 249 182)
(Brown 161 004 004)
(Mauve 224 141 202)
(Black 000 000 000)
n = listnindex(mapcar(lambda((colDef), lowerCase(car(colDef))), colours), lowerCase(colour))
when(n, colourNo = n + 1, axlColorSet(colourNo, cdr(nth(n, colours))))
when(colourNo, p = axlLayerGet(layer), p ->color = colourNo, axlSetParam(p))
  • eDave
    eDave over 8 years ago
    The first line has an extra bracket.
    try replacing it with:
  • JerryWilson
    Hi Dave
    I tried that & i'm getting this error. Please advice.
    Jerry
    Skill > load("L:/ecad_proj/MCLLIB_ZMY12_172/cjj082_adwlib/codes/col.il")
    function DE_setLayerColour redefined
    t
    Skill > DE_setLayerColour
    ERROR
  • eDave
    DE_setLayerColour("ETCH/TOP", "Violet")
  • JerryWilson
    Hi Dave
    Do i need to specify the layers & color every time i load the function? How can i load this color setup 1 time & set the color.
    I notice that 17.2 has a default color setup. Can i load the default color setup using skill & setup my colors accordingly. I was thinking of doing that way.
    Please advice.
    Jerry
  • eDave
    Hi Jerry,
    This is just an example of what you can do in a function.
    I haven't used 17.2 colours enough to know what's possible but I think using the system features will be your best approach.
    Dave
