  3. Using a script inside a foreach loop.
  • Views 16205
joma
joma over 9 years ago
I am trying to output shape reports for all etch shapes in order to check them for errors.
My foreach loop works for normal skill commands but breaks after the first pass when I use
my script to create a report:
        l_etchShapes = axlDBGetShapes( "ETCH" )
        foreach( _testEtchShape l_etchShapes
                println(list( "Shape Layer 1 = " _testEtchShape->layer )) ;print for debug
                axlClearSelSet()
                axlSingleSelectObject( _testEtchShape )
                axlSetActiveLayer( _testEtchShape->layer )
                axlVisibleDesign( nil )
                axlVisibleLayer( _testEtchShape->layer  t )
                axlSetFindFilter(?enabled list("NOALL" "SHAPES" ) ?onButtons list("ALL"))
                        shpInstOut = outfile("./shape_rep.scr")
                                fprintf( shpInstOut "scriptmode +w +i\n" )
                                fprintf( shpInstOut "setwindow pcb\n" )
                                fprintf( shpInstOut "generaledit\n" )
                                fprintf( shpInstOut "shape select\n" )
                                fprintf( shpInstOut "pick grid %L\n",  car( _testEtchShape->bBox ))
                                fprintf( shpInstOut "pop shape report\n" )
                                fprintf( shpInstOut "setwindow text\n" )
                                fprintf( shpInstOut "save\n" )
                                fprintf( shpInstOut "fillin \"temp_shp_report.txt\"\n" )
                                fprintf( shpInstOut "close\n" )
                                fprintf( shpInstOut "done\n" )
                        close( shpInstOut )
                    axlShell("replay ./shape_rep.scr")
                println(list( "Shape Layer 2 = " _testEtchShape->layer )) ;print for debug
            );foreach
Can anyone tell me how to keep the loop from being broken by the script?
  • craigl
    craigl over 9 years ago
    In short you can't. When you play a script inside of SKILL all the dbids go out-of-date. You would have to create a script for each shape, then replay the scripts.
    -Craig
