  3. display net names from SKILL
  • Views 18169
ron2015schmitt
ron2015schmitt over 9 years ago
I am looking to control, from a SKILL script/form,  the "Display Net Names Functionality" as given in the Setup>Design Parameters checkboxes:
In the documentation I found
axlDBDisplayControl('displayNetNames, t/nil)
But obviously it doesn't control the three checkboxes since it is only one parameter.
Anyone know how to do this?
  • DE202408202727
    DE202408202727 over 9 years ago
    It appears to be an oversight that you can't control these yet via axlDBDisplayControl.
    A method would be to export the Design Setting Parameters and re-import them with the changes. This is easier said than done. The values you need to change are in the <dispflag> section.
  • Ejlersen
    Ejlersen over 9 years ago
    Hi
    You could also record a script to turn these on/off.
    The script can be wrapped inside a SKILL program if you wish so
    Best regards
    Ole
  • ron2015schmitt
    Dave, thank you for your informative reply.  I will look into this.
  • ron2015schmitt
    Thanks Ole. I will look into both exporting settings and recording a script and see which is simpler.
