  3. Modify dynamic shape parameters using SKILL
  • Replies 13
  • Views 26079
migrg
migrg over 9 years ago
Hi, I'm trying to modify the shape parameters (thermal relief, void controls, etc.) using SKILL. I can access the object but I don't see any properties or parameters to modify (prop is nil). Any ideas of where those properties hide in the database? Here is what I can see in the SKILL command line, id is the dbid of the shape
id~>??
(prop nil priority -7 dynamicGroup
dbid:0x2aee03f17098 taper nil shapeAuto
(dbid:0x2aee0ca2f500 dbid:0x2aee0ca2f470 dbid:0x2aee0ca2f3e0 dbid:0x2aee0ca2f350 dbid:0x2aee0ca2f2c0
dbid:0x2aee0ca2f230
region nil bBox
((-19600.0 -19300.0)
(19300.0 19300.0)
) readOnly
t voids nil net dbid:0x2aedbf2396d8
objType "shape" segments
(dbid:0x2aee0c14ef10 dbid:0x2aee0c14ee38 dbid:0x2aee0c14eb40 dbid:0x2aee0c14e958) nSegs
4 fillet nil fill t
connect nil cavity nil branch
nil fillOOD nil shapeBoundary nil
shapeIsBoundary t isRect nil layer
"BOUNDARY/L1" symbolEtch nil parent nil
isHole nil parentGroups nil
  • B Bruekers
    B Bruekers over 6 years ago in reply to mstaub +1
    Use axlDBRefreshId(nil) or axlDBRefreshId(dbid) after the addprop. Bram
  • B Bruekers
    Your welcome.
    You need to take the shapeBoundary of the etch shape, so: dbid->shapeBoundary->dynamicGroup->prop->??
    The shapeBoundary can have multiple shapeAuto dbid's, these are the actual etch shapes. So they all refer back to the boundary where the shape overrides are set.
    Bram
  • mstaub
    mstaub over 6 years ago in reply to B Bruekers
    B Bruekers,
    Is there a command that needs to be run after axlDBAddProp( dbid->dynamicGroup '("SMOOTH_MIN_GAP"    "0.567 MM" )) for this to then be query-able from the same code that added this property? For example I have a Skill program with a form with a button to run the following code which run (any number of times) always prints the original SMOOTH_MIN_GAP value for the shape
    Skill:
    println(dbid->shapeBoundary->dynamicGroup->prop->SMOOTH_MIN_GAP)
    Output:
    0.1
    0.1
    If I close the form and run it again, the output now becomes:
    0.567
    0.567
    The shapes appear to be accepting the property and the design is updating as expected. I'm just curious if there is anything that can be done in Skill to make the updated property value readable without having to close to form.
    Matt
  • B Bruekers
    Bram
