  3. Modify dynamic shape parameters using SKILL
  • Replies 13
  • Views 26070
migrg
migrg over 9 years ago
Hi, I'm trying to modify the shape parameters (thermal relief, void controls, etc.) using SKILL. I can access the object but I don't see any properties or parameters to modify (prop is nil). Any ideas of where those properties hide in the database? Here is what I can see in the SKILL command line, id is the dbid of the shape
id~>??
(prop nil priority -7 dynamicGroup
dbid:0x2aee03f17098 taper nil shapeAuto
(dbid:0x2aee0ca2f500 dbid:0x2aee0ca2f470 dbid:0x2aee0ca2f3e0 dbid:0x2aee0ca2f350 dbid:0x2aee0ca2f2c0
dbid:0x2aee0ca2f230
region nil bBox
((-19600.0 -19300.0)
(19300.0 19300.0)
) readOnly
t voids nil net dbid:0x2aedbf2396d8
objType "shape" segments
(dbid:0x2aee0c14ef10 dbid:0x2aee0c14ee38 dbid:0x2aee0c14eb40 dbid:0x2aee0c14e958) nSegs
4 fillet nil fill t
connect nil cavity nil branch
nil fillOOD nil shapeBoundary nil
shapeIsBoundary t isRect nil layer
"BOUNDARY/L1" symbolEtch nil parent nil
isHole nil parentGroups nil
  • B Bruekers
    B Bruekers over 6 years ago in reply to mstaub +1
    Use axlDBRefreshId(nil) or axlDBRefreshId(dbid) after the addprop. Bram
  • cdlep
    cdlep over 6 years ago in reply to FoCo
    Let me add on to this as it becomes active.  I cannot find the switch for "Automatically delete isolated shapes" or "Automatically delete antenna shapes" with axlGetParam("shapeDynamic")->??.  It does not record as a preference in the env file.  How do I check/set these directives?  Thanks
  • Season
    Season over 6 years ago
    An old thread, and seems no answer. I am also looking for the way these days.
    make a long story short, axlGetParam("shapeDynamic")  can just get the global parameter of the shape.
    But how can get the parameter of a shape instance by skill, especially get the override value.
    Does any know that? Thanks.
  • mstaub
    mstaub over 6 years ago in reply to Season
    Hi Season,
    Using Skill you currently cannot modify the parameters of an individual dynamic shape, you can only do it at the global level for all dynamic shapes. I have cases submitted to Cadence regarding this exact topic. Still no word on if/when it will be implemented.
  • B Bruekers
    B Bruekers over 6 years ago in reply to Season
    Get the dbId of the shape on the boundary or etch. Then look for the ->dynamicGroup->prop  value.
    So lets assume 'dbid' is the variable with the shape dbId:
    Skill > dbid->dynamicGroup->prop~>??
    (DYN_SHAPE_PRIORITY "32334" SMOOTH_MIN_GAP "0.152 MM" DYN_FIXED_THERM_WIDTH
        "0.381 MM" VIA_THERM_CONN "FULL_CONTACT" THRU_THERM_CONN "FULL_CONTACT"
        SMD_THERM_CONN "FULL_CONTACT" VIA_MIN_THERMS "4" THRU_MIN_THERMS
        "4" SMD_MIN_THERMS "4"
    These are the specific override settings on a single dynamic shape.
    You can add/change the properties with:
    axlDBAddProp( dbid->dynamicGroup '("SMOOTH_MIN_GAP"    "0.567 MM" ))
  • mstaub
    mstaub over 6 years ago in reply to B Bruekers
    B Bruekers,
    Thanks for this tip. I find it interesting that Cadence wasn't aware of this, or at least the people we were interfacing with.
    That said, I believe if you want to retrieve these properties you can only use the dbid of the boundary, not the shape. Skill > dbid->dynamicGroup->prop~>?? on an ETCH layer shape will return nil. (at least in the quick testing I did)
