  3. Skill to run multiple script (.scr) or multiple skill f...
  • Replies 8
  • Views 23811
Skill to run multiple script (.scr) or multiple skill files
EdwinB
EdwinB over 9 years ago
Is there a way to run several script files as Skill or one skill file to run multiple skill files?
If so, how do you do this?
Currently, I'm running two skill files as a script file but would prefer to use one skill file to run multiple skill files or one skill file to run multiple script files.
Eddie
  • DE202408202727
    DE202408202727 over 9 years ago
    The simple answer is yes.
    You generally don't run Skill "files" you call functions contained in files.
    So long as the Skill file is loaded using load or autoload you can run as many functions (or procedures) as you like.
  • EdwinB
    Hi Dave,
    Thanks for the quick reply. Got it - call functions - was the correct wording.
    How do you implement this?
    For example I have this two skill files that I need to call:
    ref_des.il
    textblk.il
    How do you call the functions contained in these two files?
    Edwin
  • DE202408202727
    Like I said - you don't generally call files. You load them.
    So, in one Skill file you can have the lines:
    load("ref_des.il)
    load("textblk.il")
    I don't know what your function names are but you would generally then call the functions:
    ref_des_function()
    textblk_function()
  • EdwinB
    Hi Dave,
    I got the other il to work, but somehow this set_redes.il that I found in the forum doesn't work. Modified the print portion only.
    The "function" callout comes out 'undefined'. Will you be able to check which function to use?
    gives this error > E- *Error* eval: undefined function - srd
    Thanks for the help
    Code:
    axlCmdRegister("srd" '_set_refdes_from_file ?cmdType "general")
    procedure( _set_refdes_from_file( mode )
    prog( list(l_text refdes t_loc t_rot t_mirror t_justify t_layer l_vis l_old_loc mir rot)
    l_old_loc=list()
    case(mode
    ("save" ;save the current refdes text information to a file
    printf("Mode:save\n")
    ; printf("Saving refdes data to file refdes.txt\n")
    printf("Saving refdes data to file Harbor_Silk_RefDes.rpt. Check your working folder. \n")
    p_refdes=outfile("./Harbor_Silk_RefDes.rpt") ;open a file to store the data
    ; p_refdes=outfile("./Harbor_Silk_RefDes.txt") ;open a file to store the data
    axlClearSelSet() ;clear any selected objects
    axlSetFindFilter(?enabled '(noall text) ?onButtons '(text))
    l_vis=axlVisibleGet() ;Store the current layer visibility
    axlVisibleDesign(nil) ;Set the visibility as desired.
    axlVisibleLayer("REF DES/SILKSCREEN_TOP" t )
    axlVisibleLayer("REF DES/SILKSCREEN_BOTTOM" t )
    axlUIWUpdate(nil)
    axlAddSelectAll() ;Select all of the visible text
    l_text=axlGetSelSet() ;Save the selected text in a list
    axlClearSelSet()
    foreach(text l_text ;Check each text string
    parent_type = text->parent->objType
    text_class = car(parseString(text->layer "/"))
    if(parent_type == "symbol" && text_class=="REF DES" then
    ;probably found a refdes. Store the text details
    refdes=text->text
    t_loc=text->xy
    t_rot=text->rotation
    t_mirror=text->isMirrored
    t_layer=text->layer
    t_textblock=text->textBlock
    t_justify = text->justify
    ;write the data to a file
    println(list(refdes t_loc t_layer t_rot t_mirror t_textblock) p_refdes)
    );endif
    );end foreach refdes
    close(p_refdes) ;close the file
    axlVisibleSet(l_vis)
    axlUIWUpdate(nil)
    printf("Harbor_Silk_RefDes.rpt file save completed.Check your Working directory folder\n")
    );save
    ("get" ;Read the file and process the text
    printf("Mode:get\n")
    l_visible=axlVisibleGet() ;store current visibility settings.
    axlVisibleDesign(nil) ;turn everything invisible
    p_refdes=infile("./refdes.rpt")
    while(l_refdes=car(lineread(p_refdes))
    refdes=nth(0 l_refdes)
    loc=nth(1 l_refdes)
    layer=nth(2 l_refdes)
    new_rot=nth(3 l_refdes)
    new_mir=nth(4 l_refdes)
    new_tblock=nth(5 l_refdes)
    new_justify=nth(6 l_refdes)
    l_old_loc = _find_refdes(refdes layer) ;call procedure to find the original text
    old_xy = nth(1 l_old_loc) ;current coordinates of refdes
    old_rot = nth(0 l_old_loc)->rotation ;current refdes rotation
    old_mir = nth(0 l_old_loc)->isMirrored ;current mirror status
    old_tblock=nth(0 l_old_loc)->textBlock ;current text block used
    o_component=nth(0 l_old_loc)->parent ;need the parent if creating new text
    when(old_xy ;if there is an xy then we found the text and can do a transform
    if(old_tblock==new_tblock then ;if the same text block then do a transform
    delta_x=xCoord(loc) - xCoord(old_xy) ;calculate the x offset
    delta_y=yCoord(loc) - yCoord(old_xy) ;calculate the y offset
    l_delta=list(delta_x delta_y) ;distance to move the text
    rot=new_rot-old_rot ;calculate the rotation
    mir=(new_mir && !old_mir)||(!new_mir && old_mir) ;mirror is XOR
    axlTransformObject(car(l_old_loc) ?move l_delta ?mirror mir ?angle rot) ;move the text
    else
    ;if textblocks don't match then create a new refdes.
    new_orient=make_axlTextOrientation(?textBlock new_tblock, ?rotation new_rot, ?mirrored new_mir, ?justify new_justify )
    new_refdes=axlDBCreateText(refdes, loc, new_orient, layer, o_component)
    if(new_refdes then ;if new refdes successful then delete old one.
    axlClearSelSet()
    axlSingleSelectPoint(old_xy)
    axlDeleteObject(axlGetSelSet())
    axlClearSelSet()
    );end_if
    );end_if
    );end_when
    );end while
    close(p_refdes)
    axlVisibleSet(l_visible) ;restore layer visibility.
    printf("Process complete.\n")
    );get
    (t
    printf("Invalid command line argument.\n")
    printf("Command syntax: srd save or srd get \n")
    return(nil)
    );endcase
    );endprog
    );endproc
    procedure( _find_refdes(sym tlayer)
    ;procedure to return the dbid and location of the refdes for the symbol
    prog( list(child l_children o_type o_layer match_loc)
    l_children = car(axlSelectByName("REFDES" sym))->children
    foreach(child l_children
    o_type = child->objType
    o_layer = child->layer
    if(o_type=="text" && o_layer==tlayer then
    ;probably found a refdes match.
    match_loc=child->xy
    axlClearSelSet()
    return(list(child match_loc)) ;return the dbid and location of the text
    ;if match_loc returns as nil then the text was not found
    );endif
    );foreach child
    );end prog
    );end proc _find_refdes
  • DE202408202727
    type "srd" in the Allegro console window. Not the Skill window.
