  3. Need only one particular pin of ref des (TESTER) of a given...
  • Views 13736
Need only one particular pin of ref des (TESTER) of a given net name
chbt
chbt over 8 years ago
I need to make a utility in which only tester ref des will given as output when I input the nets.
For example: Net name +5v is input net and output will be J225 no capacitors, resistors, or any component ref des will appear.
Although Allegro generate net-list report but it shows ref des of all components in particular net path.
