  3. Export used class and sub class
  • Views 15813
LoGanathan
LoGanathan over 8 years ago
I would like to see what are all the class/sub class is used in the allegro footprint.
  • B Bruekers
    B Bruekers over 8 years ago
    A possible way:
    axlSetFindFilter(?enabled '("invisible" "all") ?onButtons '("all"))
    axlAddSelectAll()
    l_objects = axlGetSelSet()
    l_layers = remq(nil unique(l_objects~>layer))
    axlClearSelSet()
    Bram
  • DavidJHutchins
    DavidJHutchins over 1 year ago in reply to B Bruekers
    I noticed an anomaly when trying this, it reports "TOP" & "BOTTOM" without a Class prefix, below is the bottom of my journal file:
    \d (00:26:05) Design opened: C:/Cadence/SPB_22.1/share/pcb/examples/board_design/cds_routed.brd
    \i (00:26:05) shapeedit
    \i (00:26:13) skill 'load("classes.il")'
    (00:26:13) function classes redefined
    (00:26:13) t
    \i (00:26:19) skill 'pp classes'
    (00:26:19) procedure(classes()
    (00:26:19) let((l_objects l_layers)
    (00:26:19) axlClearSelSet()
    (00:26:19) axlSetFindFilter(?enabled
    (00:26:19) '("invisible" "all") ?onButtons
    (00:26:19) '("all")
    (00:26:19) )
    (00:26:19) axlAddSelectAll()
    (00:26:19) (l_objects = axlGetSelSet())
    (00:26:19) (l_layers = remq(nil
    (00:26:19) unique((l_objects~>layer))
    (00:26:19) ))
    (00:26:19) axlClearSelSet() l_layers
    (00:26:19) )
    (00:26:19) )
    (00:26:19) nil
    \i (00:26:23) skill (classes)
    (00:26:23) ("TOP" "ETCH/TOP" "ETCH/BOTTOM" "ETCH/VCC" "ETCH/GND"
    (00:26:23) "DRAWING FORMAT/DRAWING_ORIGIN" "BOTTOM" "BOARD GEOMETRY/TOP_ROOM"
    (00:26:23) )
  • DE202408202727
    DE202408202727 over 1 year ago in reply to DavidJHutchins
    TOP and BOTTOM are the "layers" that symbols are on. They don't have a class. I think using "layer" for the name of the attribute for symbols is just a convenience.
    Is this new, that symbols have a layer? I don't recall this in older versions of Allegro.
  • DavidJHutchins
    DavidJHutchins over 1 year ago in reply to DE202408202727
    Thanks for the clarification, it was documented as far back as 17.4...
  • DavidJHutchins
    DavidJHutchins over 1 year ago in reply to DavidJHutchins
    I changed the find filter to the following:
    axlSetFindFilter(?enabled '("INVISIBLE" "ALLTYPES" "NOSYMBOLS") ?onButtons '("ALL"))
    to resolve the issue :)
