  3. How to replace the Dummy net
  • Views 16734
krthik15
krthik15 over 8 years ago
Is it possible to replace the "Dummy net" with any other net using Skill?
i tried "axlDBAssignNet" it shows following message
W-  Cannot change net on element type: Net "Dummy Net".
-karthik.K
  • B Bruekers
    B Bruekers over 8 years ago
    First you need to create a net with axlDBCreateNet(), or fetch the dbid of an existing net with axlDBFindByName()
    Once you got a net dbid you can assign this to pins, vias or shapes with axlDBAssignNet()
    "dummy net' value is just like a '#refdes',  nil.  If you look at a pin with a 'dummy net' you will see that it has a net dbid value of 'nil'.
    With other words, you cannot 'change' the dummy net name, only create or use an existing net dbid and assign it to pins.
  • krthik15
    krthik15 over 8 years ago in reply to B Bruekers
    Thanks Bruekers!!
    Actually, i have  created the " test point footprint" and placed over the selected "cline seg " also need to assign the selected "cline seg net" into testpoint net.
    existing cline seg net has  "dbid" but test point net has "dummy net" (nil) so, how to create the dbid of test point net?
