  3. TCL command for "Tools > Export Properties.." in Capture...
  • Views 2454
TCL command for "Tools > Export Properties.." in Capture CIS
aricbeaver
aricbeaver over 8 years ago
I'm looking to automate the export of part properties from OLB files. Does anyone know if there is a TCL command/function that can use export part properties? This generates an EXP file that I am going to use for revision control of the OLB files.
I've turned on Journalling of the TCL commands and the commands that are used would not operate via the Windows command line shell as it uses the Menus/Dialog boxes.
Capture> Menu "Tools::Export Properties" | DialogBox  "OK" "C:/Users/AppData/Local/Temp/CAPTURELOG/Fri_May_04_13_48_43_2018/Export Properties_1.xml"
Here is a picture of what I am trying to automate:
