  3. Replace footprint on PCB Editor
  • Views 14546
WongWingJoshua
WongWingJoshua over 8 years ago
  1. I need to replace an obsolete component on an existing board, from 100-TQFP to 128-TQFP. How should I implement it on PCB Editor, after all, how should I verify the change?
  • oldmouldy
    oldmouldy over 8 years ago
    You have posted this question in the wrong forum again, this is a PCB Design question, not intended for the PCB SKILL form which is related to the SKILL coding language. IF you want to change a footprint in PCB Editor, you need to load an updated netlist with the changed footprint to effect any change in the board.
