  3. Automating STEP export
  • Views 16740
Arashk
Arashk over 8 years ago
I am looking to write a script that will create STEP file and .zip it.
Is there a function related to this?
-Arash
  • DE202408202727
    DE202408202727 over 8 years ago in reply to Arashk +1
    Find the help files for batch utilities in \share\pcb\batchhelp Look at the step_out.txt help file. This will tell you the syntax of the command that you need to use. Once you have developed your command…
  • DE202408202727
    You can use the step_out batch file.
  • Arashk
    Arashk over 8 years ago in reply to DE202408202727
    Hey Dave,
    Could you please elaborate on that? I am new to SKILL and have no idea what that is.
    Cheers
  • DE202408202727
    Once you have developed your command you can call it using the Skill "system" command.
  • BhuvanHL1
    BhuvanHL1 over 3 years ago in reply to DE202408202727
    Hi Dave,
    Kindly help to provide the full script to export the .stp
  • DE202408202727
    DE202408202727 over 3 years ago in reply to BhuvanHL1
    I can't tell you what your parameters are.
    Run step_out in a command shell and go from there.
