  3. Best way to do blind/buried RF vias?
  • Replies 10
  • Subscribers 166
  • Views 7727
jayk314
jayk314 over 8 years ago
I have some RF nets routed on internal layers.  The layer transitions typically involve a number of micro-vias (i.e. 1-2, 2-3, etc.) and sometimes buried vias.  In either case, I often need to clear out antipads on the layers above and below the via capture pads to get rid of extra capacitance.  For example, if I'm going from L2->L3 and I have ground plane on L1 and L4 I'd need anti-pads on L1 and L4.
The way I've been doing this is to create, say, a b/b via in the Pad Editor from L2->L3 and then manually adding voids on the PCB on L1 and L4.  This is tedious and error-prone, and it's a pain if I have to move that via later.  I can create the via in the Pad Editor with the anti-pads (but no Regular Pad) defined on L1 and L4, but then the hole for that via is generated in the L1-4 drill file, not in the L2-3 drill file as it should be.
Can anyone think of a better way to do this?
  • mcatramb91
    mcatramb91 over 8 years ago in reply to jayk314
    Using the ADJACENT_LAYER Pad geometry is the way to go.
    It is a two step process
    1. Add the ADJACENT_LAYER Pad geometry to the padstack
    2. In the design, add the property ADJACENT_LAYER_KEEPOUT_ABOVE and ADJACENT_LAYER_KEEPOUT_BELOW
    The property can be added directly to a Pin/Via in the design with a value representing how many layer to add adjacent layer keepouts after the last pad layer.
    I good application of this is to add the property to an SMD Pin that requires voiding on the adjacent layer, entering a value of 1 would generate the keepout on the first adjacent layer.
    Hope this helps,
    Mike Catrambone
  • jayk314
    jayk314 over 8 years ago in reply to mcatramb91
    Mike,
    Thanks so much.  I just got the same advice from Ron at EMA.  This is exactly what I needed.
    Jay
  • redwire
    redwire over 8 years ago in reply to mcatramb91
    So if my 16.x customers that need this would upgrade to 17.x we could save a lot of time!  Most are still reluctant to move up to 17 since it lacks a backwards compatibility which is a huge issue in most companies.
  • Tmills
    Tmills over 8 years ago in reply to jayk314
    For RF designs we will typically also add a Backdrill and the necessary Backdrill information. This is pretty easily accomplished in Allegro v17.2.
    Setting up Backdrills is under Manufacture..NC...Backdrill Setup.
    Setting up the padstack correctly is the real 'art' to getting this to work properly and leverages off of the anti-pad discussion above.
    Here is one example of a 12 layer stackup with a 1-6 pad and a 7-12 backdrill.
    You will end up with a unique drill file for each backdrill.
  • Duc Nguyen SV
    Duc Nguyen SV over 6 years ago in reply to mcatramb91
    I don't quite understand the way to do : how to "Add the ADJACENT_LAYER Pad geometry to the padstack"
    do any one  have pictures show step to do?
