  3. STEP files not updating in board (but update in some symbols...
  • Replies 7
  • Subscribers 169
  • Views 21627
STEP files not updating in board (but update in some symbols)
tinyspud
tinyspud over 7 years ago
I'm having this weird issue - I'm trying to add connector heights so I can verify things with the mechanical engineer so I've been adding step files to my existing parts and some of them are updating and some of them aren't.  I've been using the STEP mapping from the setup menu and when I set up the offsets and orientations then save and refresh the package symbols some of them update and some of them are still not visible in the 3D view.
I've tried updating the individual packages, all of the packages, updating the STEP mapping data only and ignoring the FIXED property.  I see the mapping information in the element information but I still can't see the STEP files in the 3D view.
I'm confused as to what to do - are there any debug logs or anything I can see?  All of the STEP files (the ones that work and the ones that don't) are all in the same place, all of the mapping files are in the same place and so far as I can tell the metadata is where it should be.  The step files render fine in the step mapping views so I'm assuming they're understood properly in OrCAD.  What else should I look into?
Thanks!
Chris
  • steve
    steve over 7 years ago +1
    Firstly make sure you are running the latest hotfix so 17.2-2016 S049 available from Download Manager or the Cadence support site http://support.cadence.com . If you are then it could be the actual STEP…
  • FormerMember
    FormerMember over 7 years ago +1
    I had a similar problem. In my case, I finally discovered that I had initially mapped a step file to a "Device" and then later tried mapping a different step file to the "Package". It was not until I deleted…
  • JFuoco
    JFuoco over 7 years ago +1
    Another thing to try, and I'm not sure why it matters: View -> 3D View. View -> Dynamic Layer Visibility. Check that that is enabled; it makes a difference for me with certain models showing up.
  • aricbeaver
    aricbeaver over 5 years ago
    For me the issue was the height property was set to zero in the Setup > Areas > Package Height.
  • PT202502243838
    PT202502243838 over 1 year ago
    Here's what worked for me (using version 22.1):
    1. Place
    2. Update Symbols
    3. Check box next to particular component under Package Symbols
    4. Check box next to "Update STEP mapping data only"
