  3. change radiobutton text dynamically
  • Views 14422
Ejlersen
Ejlersen over 7 years ago
Hi
I'm currently working on a form where I would like to be able to change the radiobutton (Checklist) text dynamically.
Example. 3 radiobutton choices
- 1.0
- 2.0
- 3.0
If I then select 3.0 it should change to show
- 2.0
- 3.0
- 4.0
I've not found a way to do this, is it even possible?
Best regards
Ole
  • DE202408202727
    DE202408202727 over 7 years ago
    I don't think that's possible. Of course you could just give your radiobuttons blank labels and use text fields (with labels) and change those as required.
  • Ejlersen
    Ejlersen over 7 years ago in reply to DE202408202727
    Hi Dave
    That's the way I've done it so far, but think I'll close the program and restart it instead - that should work for the purpose since I'm not too keen on the text methodology
    Ole
